question about clothing in the "old days"
I have clothing from G2 and even some G3 and I could crack up the morph values to 1000% or more and there would be no poke throughs. Now with G8 and some G3, even if I increase the vascularity within the normal levels, I get poke throughs.
Why didn't it happen before and why is it happening now and is there anything I can do to keep it from happening with G8 and G3?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,505
    autofollow
    You've tried a push modifier?
  • Drogo NazhurDrogo Nazhur Posts: 1,340
    No. I have no clue what that is. Can you please provide a link explaining it?
  • HavosHavos Posts: 5,703
    Could it be that the G3 and G8 characters giving you poke through are HD?. A lot less G1 and G2 characters were HD. The reason this is relevant is that autofollow does not follow HD morphs (or so I believe) and I imagine in the modern figures vascularity is done using HD morphs.
    If you use no HD morphs on G3 and G8 are they still giving as much poke through?
  • BeeMKayBeeMKay Posts: 7,019
    edited March 2023
    There's tutorials if you use your google foo, but the simple way is:
    1. Select the item
    2. Edit --> Object --> Geometry --> Add Push Modifier
    3. Enter the name of the Pushmodifier (Dress) or leave it at default
    4. In the parameter tab of the item the control is under: General --> Offset Increasing/decreasing the value and see when it looks good.
    Post edited by BeeMKay on
