Get Funky skirt won't render
dakkuuan
I have the Get Funky for G2F that was part of the Fantasises Attic 2013 Halloween event. It can be found here but the files aren't active. http://freezone.thefantasiesattic.net/index.php?main_page=product_info&cPath=138_144&products_id=89 But for some reason, the skirt won't render. If you up the skirt on it's own, the render will stop around the heart shaped metal pieces. Daz won't cancel the render and I have to shut it down with task manager. I've tried hiding the metal pieces and it doesn't help. Any ideas?
Sometimes D|S will see a new material (especially if it's a custom shader) and stop everything while it sits and thinks for a bit. Are you sure it isn't just a temporary pause? How long are you waiting? Depending on <insert long list of possible causes> the pause could be less than a minute, or several minutes.
