Do OBJ Files Contain Textures?
Software applications I work with apparently will soon be upgrading to where you can import OBJ files and work with 3D objects. But... do OBJ files contain texture and color information? I'll less excited if this is not the case. Thanks
  • LeanaLeana Posts: 13,627
    They do, but rather basic ones IIRC.
  • barbultbarbult Posts: 27,641
    I didn't think OBJ files had texture information at all. Sometimes they come with a companion mtl file that lists the path to some separate texture files, but those mtl files seldom work for me in Daz Studio. It could be that I just don't know how to use them properly.
    Ah good point, I was thinking about the mtl file not the obj itself
    The path to the textures inside the MTL file is absolute, and usually doesn't match where one placed them. Once the paths are fixed, the textures are loaded with the model.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,752
    they can have very highly detailed vertex colours but only some software's see them
    it's also dependent on mesh resolution
    fractal exports from Mandelbulber3D have very detailed painting and highpoly, Zbrush, Meshlab and Ultimate Unwrap 3D can see them out of the software I have
    I suspect Substance Painter and other software that does 3D painting can too
    it's what Zbrush calls polypaint
    we a talking about meshes with millions of faces here
    they don't need UV mapping or mtl files
  • GordigGordig Posts: 10,822
    How well they work will also depend on the render engine, as different engines use different naming conventions for both parameters and maps.
  • UncannyValetUncannyValet Posts: 277
    edited March 2023
    so... solution: manually add the textures to obj whenever needed
    Post edited by UncannyValet on
  • AscaniaAscania Posts: 1,856
    edited March 2023
    No. The solution is to manually set up the textures on the obj once and then save it to the library as a DAZ asset.
    Post edited by Ascania on
    Hmm, I clearly missed the part of OP's post where they said they were talking about Daz Studio...
    "Whenever needed" was not me advising the user to repeat busywork anytime they use an obj, but rather i meant that when using new obj for first time, they need to set up textures manually rather than entrust some automatic process to accurately assign textures to shader setup correctly.
    The OP didn't specify what programs they're working with, but if the programs are only now adding OBJ import capabilities, they're clearly not talking about DS.
    In non-D|S software the solution is to set up the textures on the obj once and then save it as a native to the program asset.
