G8F Morphs to G8M
Hey,
I have created morphs on G8F / G8.1F (ears) and would like to transfer these ear shapes 1:1 to G8M / G8.1M.
Is this possible and if so, how can I make it so that I can apply the shapes to the other Genesis gender?
thank you so much for your help :)
bests
  • MasterstrokeMasterstroke Posts: 2,515
    I reall don't know. Why don't you just try?
    Export you G8m at base resolution as Obj and load the ObJ via morph loader into G8f.
    Either it works or it doesn't.
  • benniewoodellbenniewoodell Posts: 2,001
    Hmm, I've never known about morph loader. I'll have to look that up later and see as I've had this same question too.
  • CHWTCHWT Posts: 1,191
    Can the method to transfer G8 morph to G9 be applied?
  • Matt_CastleMatt_Castle Posts: 3,306
    edited March 2023
    That definitely doesn't. Their geometry doesn't match.
    You need the Transfer Utility, not Morph Loader.
    The best method is to have something like UV Swap, because then you can set one or other figure to the other's UVs and tell Transfer Utility to use UV Space as its basis for transferring morphs, which avoids the difficulties with trying to match vertices in three dimensions.
    I can't easily give a full description of how to use the Transfer Utility to its fullest while I'm on my tablet, but hopefully that's some information to set things in a useful direction.
    Post edited by Matt_Castle on
