How to change the default background color
Could someone please tell me how to change the default background color? I saved my startup scene in preferences to have a grey background but everytime I open a new scene the background is black.
  • fixmypcmikefixmypcmike Posts: 19,733
    Edit > Preferences > Scene, under "Backdrop Color" tick the box for "Ignore Settings When Opening a Scene File"
  • Well that does't work. The srceen is grey when I first start up Daz. But when I open new blank scene, it's black again
    Ah, sorry, I thought you meant when you open a saved scene.  in Edit > Preferences > Scene, put your startup scene in On New Load File.
  • In the menue: Window - Style - Customize Colors. Last entry is the Viewport color, you can change it there to the grey color :)
  • Thanks, I think that did it
  • My question is similar but different. In older versions of DAZ, i used to get a light blue background in my renders wherever the scene was empty. In later versions it was white. Now they're black. I'd prefer blue or even white, or at least some other lighter color; in my test renders anyway (I don't care how it looks in my view pane). What do i need to change to make *that* happen?
    Window > Panes > Environment, set Ytpe to "Backdrop" and choose the desired color.
  • Yeah, that's a LOT better! thanks! :-)
  • BeemBeem Posts: 95
    edited June 2018
    Where do i find  Ytpe mentioned below ?
    Post edited by Chohole on
  • Richard HaseltineRichard Haseltine Posts: 111,765
    It should say Type, the first option in the Environment pane.
    edited June 2018
    Now i found it- Thank you.
    Post edited by Beem on
  • digitalshotdigitalshot Posts: 0
    edited August 2020
    Thanks for the info, this was it. :)
    Mod Edit :- To sort out the quote.
  • VueiyVueiy Posts: 611
    Thank goodness!  I had changed it to gray before, probably using these exact steps, but when I double-clicked on a product that opens a scene, it overwrote that, and I was  stuck w/ a black background...and had forgotten how I'd changed it in the first place.  I wish they'd add back the feature where you could just right-click on a blank spot in the scene, and it'd let you change the color there.  Now I have to try to remember which products change the color...
    Keep in mind that you have to keep "View in Render" on for them to show up and not have a transparent background.
  • ShelLuserShelLuser Posts: 749
    Also keep in mind that Beem asked that question 3 years ago and many things have changed between then and now. Just mentioning because sometimes it may seem as if people are doing some things wrong while in fact they're doing it right because that's simply how it was done back then. Not saying that this applies here, just mentioned as example.
    thank u d .You help me so much.
