She Freak morphs not working (worked only once??)
RobertDyRobertDy Posts: 277
She Freak is a muscularity morph for V4, https://www.daz3d.com/she-freak-v4 . On DAZ 4.16 I noticed that these morphs don't show up, there's a red dot next to the icon in the Content Library, and the product itself is blank, so I had to copy and paste all the files from my old PC's DAZ into this 4.16's folder.
When I went to Poser Formats --> Pose --> DAZ's Victoria 4 --> Morph Injections, I could see the She Freak files there so I loaded it and it worked on a V4 figure. However, it failed to load on subsequent V4 figures - the morph doesn't show up as a dial at all. I ran DZcreateexpfiles-V4bat, doesn't work. How did it work only on that 'lucky' V4 figure and why won't the morphs work again???
Post edited by RobertDy on
  • Do you use the PowerLoader script 9that is, do you get a dialogue box when you load the figure)? Is there only one /Runtime/!daz/Victoria4/ folder among your content directories?
  • RobertDyRobertDy Posts: 277
    Whenever I load a V4 figure the PowerLoader dialogue emerges, but I don't see She Freak in there. I just load it with everything checked anyways (morphs++, muscle). I have two hard disks that have the folder you mentioned, one from my old PC (which is put as a secondary drive in my current PC), and one from my current PC. Regardless of which DAZ program I use, the content paths follow the ones on my new PC, and on my new PC there is only one such folder that you menioned.
  • And are the Shefreak files in the /Runtime/!daz/Victoria 4 folder? See the zip for names and sub-folders.
    I'd presume everything is complete because the first time I tried to load it there was a file missing, then I put that file in and the morph loaded (on that 'lucky' figure), then in subsequent tries when I loaded the morph, there's that very quick pop up which disappears but nothing happens, it doesn't prompt me to locate a missing file so yeah I think I have all the files. I don't have the ZIP, there doesn't seem to be a way to retrieve it as well.
    https://www.daz3d.com/downloader/customer/files#prod_9499
    It's working now, you save lives as usual! Can I ask though what was lacking, I thought since the loader didn't prompt me for anything then that should mean that all required files are available?
  • Richard HaseltineRichard Haseltine Posts: 111,332
    The loader scans the one library folder for isntalled products - if, for some reason, a product isn't theer then the loader won't know it should be. Using the manual updater route if files were theer and added to the list then they will be missed, and I would assume generate errors, on trying to load the figure but they would not be missed if they were even slightly off in their placeemnt.
