I need help with the SY Clothing Breast Helper for Genesis 8 Female
nabob21nabob21 Posts: 1,058
edited February 2023 in The Commons
Hello,
I have the SY Clothing Breast Helper Genesis 8 Female product and I am confused about how to make this product work. I have a G8.1 female in my scene and I have added a dress to the character. I have selected the G8.1F character and applied the Breast Helper morphs but when I activate the morphs in the character ther is no apparent effect on the dress. Can anyone tell me what I am doing wrong?
Thanks in advance for any replies.
nabob21
Post edited by nabob21 on
    I have just tried it with a random dress and the dialing morphs are having an effect. What Dress are you using it on? Perhaps it has something else which is conflicting? Is there anything relevant in the logs from the time when you apply the morphs and/or after?
  • nabob21nabob21 Posts: 1,058
    Hello SofaCitizen,
    I was trying to use the morphs with the DressedUp Collection Dress#1. I am not sure about what I should be looking for in the logs. I didn't get any kind of error message.
    I tried the morphs with some shirts as well with the same result.
    nabob21 said:
    Hello SofaCitizen,
    Ahh, well that should work OK as per the examples attached.  Please forgive the slightly extreme test model and zoomed crop but it seemed the best way to show the difference. The morph values are attached to show what I used for the second image.
    If this is not the experience you have then you can try loading up a fresh G8F with the dress from that product.  But before applying the morphs, go to Help/Troubleshooting/View Log File. Then when the log file comes up, either delete the whole contents or you can just scroll to the bottom and type "---MARK---" or something similar and save the file. This will give you a reference point for the next step. Now select your figure and apply the Breast Helper to the figure, then try dialing some of the morphs. At this point you can View your log file again and see if anything new has been output after the mark you made.
    500 x 400 - 228K
    500 x 400 - 227K
    756 x 806 - 496K
    SofaCitizen,
    I have tried what you have suggested with no success. In the log file nothing is written after I try to apply the morphs even with everything set to 100%. It is very strange.
    Also, do you know of any way to remove the morphs from the character so that I can try to apply them again?
    Not that I am aware of.  It might be best to save your current work and start a fresh test in a brand new scene and G8F using the above steps as I imagine that if the morphs were already applied then trying to apply them a second time would not have any effect.
  • nabob21 said:
    Hello,
    nabob21
    IDK if it's relevant, but the product page doesn't mention anything about supporting Genesis 8.1.
    Good spot, although I did my test with the G8.1F dev load so it should still have some effect.
