Axis Tool Has Disappeared
I am Using the latest version of DS 4.8.  I recently started a project and for some reason, the Translation/Rotation Tool has disappeared from the screen.  I can move my objects through the translation/rotation pane, but there are times when it's much easier to just grab a handle and do it manually.  In case I have the name of the tool wrong, I referring to the little XYZ Axis that appears when you select an object.  I have no idea how I turned it off, and I can't seem to find how to switch it back on.  In all the years I've been using DS, I've never had this happen. I know this problem probably has a very simple solution that I am overlooking, but it's making me a little crazy. Any help will be greatly appreciated.
Thanks!
  • srieschsriesch Posts: 4,243
    From the menu, select Tools, then pick whichever tool you wanted.  Not sure if you wanted just the Translate tool (circled in the screenshot) and/or Rotate, or the Universal tool that allows translate and rotate together.  You can also select the tool's icon from the toolbar, if your toolbars are laid out that way.  (In my screenshot I can select the universal tool from the toolbar, but the Translate tool isn't there because I didn't put it there.)
    969 x 398 - 59K
  • Thanks you for the help!  It solved my problem (except for the headache I have from slapping myself for missing such an obvious solution)
