Shirt texture issue
These lines are showing up on the shirt of my character. Any idea how to fix it? I already tried setting the instancing optimization to memory in case it was that but it isn't.
  • felisfelis Posts: 6,539
    It is mesh intersecting.
    Does the character have a geoshell?
    Is there a way to fix it if it's from kitbashing? The collar, skirt, and shirt are all 3 seperate things so I have the opacity of some things turned off.
    You could give the shirt a push modifier and set it to 0.1.
    And it that causes problem with the next layer, do the same to that, so basically pushing the clothing slightly away from each other. If needed using a weightmap.
    Not everything has to done in DS. Really simple to clone out in Photoshop or even with the free Snapseed mobile app with the healing tool.
    Thank you this fixed it.
