Rebuilding workstation - is there a mass installer?
Hi. I have a lot of old content, and I mean old...from the early v3 days. Also there are a lot of RDNA and renderosity files as well. Is there such a thing as an installer program that works with both? I feel like I have seen such a thing in the past, but, hey...my memory isn't what it used to be!
Regards,
Jarrett
    If the content came from Daz 3D then it will still be in your product Library and can be installed using DIM.  But it won't work with the Rendo and RDNA stuff.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,387
    edited September 2015
    If zips you might be able to mass extract them, select all then run universal extractor if it's your default open with option, then search runtime and select all the results cut and past to one folder merging, I did it with my Poserworld CD's but not perfect some things nested or in odd spots I had to fix.
