Need help with weird artefacts when using stockings with their shaping
tyra_oeildeloup
Hello
So when I use the very beautiful Queen of Darkness Expansion for Mystique 2 , and the shapings included in the product, on my character which has only Voluptuous and Olympia as morphs (aside from the breast, there I have some third party product involved, but that's not the point here) has those weird artefacts appearing (Picture 1) . Changing the size of the clothing parts to the point the garters and stockings are way too large will erase some of them, but not even all. (Pic.2)
Victoria 8 has the same problem, and she's not especially thick...(Pic.3)
Could someone give me an hand here ? I have no idea what can cause that...
599 x 363 - 262K
499 x 343 - 258K
493 x 445 - 382K
Post edited by tyra_oeildeloup on
I don't own this product. My first instinct would be to try and fix it using Smoothing parameters.
Thanks, I will check this !
It may be that only some areas are separate enough to get shadows, though that is more usually an issue with 3Delight rather than Iray.
See the holes in the stockings? Especially that heart-shaped one in the first image? That's caused by the stocking geometry intersecting with the leg geometry. I've seen those black squigly lines with hair products that intersect the head. This could be a smoothing issue, or your character has a different subdivision level than the stockings and the geometry is colliding.
