Dimension/Size of viewport - HELP
Hi Guys,
How I can chane Dimension/Size of viewport? I want it to be more wide, I also want to render it as wide images.
Thanks!
    Under Render Settings > General, set it to custom or to one of the preset aspect ratios
  • You can collapse the panes on either side of the Viewport, or reduce their size by dragging at the edge
    You can also use Shift+F11 to make the Viewport full screen
