criticism on pose sets
cosmo71cosmo71 Posts: 3,609
edited September 2015 in The Commons
Hello,
I really like pose sets and use them a lot, what I do not like since the genesis figures and have to criticize is that nearly every pose in a pose set also has expressions and nearly every time I had to restore the head just to get the expression of the face to default. Is it not possible to create full body poses without expressions and add the expressions extra?
Post edited by cosmo71 on
  • It is possible. Some sets have expressions that the artist thinks should go with the pose and they include it.
    Check the expressions section and turn the dials in there to zero.
  • LindseyLindsey Posts: 2,017
    I consider pose sets that comes with expressions a bonus as most pose sets don't include them.  Personally, I would create or locate a reset expression from another set and add it to the scripts menu --> Select the head reset preset, right click and select Create Custom Action
  • nDelphinDelphi Posts: 1,974
    I consider them a bonus too, but only when they are separate from the pose set. Many pose sets include them separate.
  • cosmo71cosmo71 Posts: 3,609
    seperate is good, included in the pose is bad :) so we have the same opinion on that :)
  • ScavengerScavenger Posts: 2,677
    I'd like expression sets that have smirks, sarcatic smiles, evil grins....
    Not really on topic, but I've been wanting to mention it somewhere. :)
  • cosmo, are you saying that the pose sets you have DO have expressions and are you asking if pose sets can be made with poses and expressions separately, rather than what you have?  What sets are you working with that do this?  I know when I've done expressions in my pose sets, they are separate.  I also add a pose to zero out expressions because adding another pose will not normally remove an expression and if a second expression is added, it can compound over the first one.
    expression sets are good and also good included in pose sets but seperated from the pose itself. I use a lot of expression on v4 but I like the expressions seperated from the poses I use..
    have some "model pose" sets for g3f, must have look but right now my machine renders an image.
  • XtraDimensionalXtraDimensional Posts: 563
    I don't know that I have a single pose pack that applies an expression at the same time.
    What products are you using that do this?
    Post edited by XtraDimensional on
  • ANGELREAPER1972ANGELREAPER1972 Posts: 4,829
    think a few of mine sometimes have had matching expressions to some poses not sure wich though as when I select poses I look in the all files options but usually when they are they fit with the pose. ironman13 though she does a lot of great poses and a lot of her stuff not only do you have a full pose option you also have mix match options with seperate poses for upper lower parts of the body, seperate arm poses left and right same with the legs, even has a lot of mix match expression poses where you can select diferent eye, mouth and other facial expression combos like tongue don't think she's done a nose one yet yet anyway but she may
    she's released a new v7 expression set today too i13 100 Essential Expressions for Victoria 7
    wonder if she sits in front of the mirror to get these ideas she comes up with a lot of interesting ones
    Post edited by ANGELREAPER1972 on
  • HorusRaHorusRa Posts: 1,665
    Yeah I wish I found pose sets with expressions. I never find that. But I can see the need to be able to turn them off at will.
    there are a few, and some have teh expressions seperate. most of the time no however.
    I like the pose sets of I13 and have tons of I13 poses for V4 :) most of them bought at renderosity
    Me too..elsewhere I have a thread on my failures at converting them for G2F :(
