Irritating power pose issue.. (SOLVED - but no explanation for orignal problem)
HamEinarHamEinar Posts: 138
Can anyone shed some light on this conundrum:
In order to use power pose on any G8 figure I first have to load a G9 figure, activate power pose, then select the G8 in question. If I don't do this, nothing but Base shows up when selecting G8.............?!
Post edited by HamEinar on
  • felisfelis Posts: 6,541
    I don't think I follow.
    For using Powerpose, I select a character, open the powerpose pane and start adjusting.
  • Shows up where? A screen shot or two may help (but if the figures need to be shown either clothe them or switch to a non-textured drawstyle).
  • HamEinarHamEinar Posts: 138
    Here you go - a visual representation from loading base G8F until being able to use PowerPose after adding G9 - it's as if PP is not initialized before being activated on a G9 figure..
    2885 x 1314 - 971K
    ...and I have tried to uninstall and reinstall both the G8 and G9 starter essentials..
  • I'm not sure why loading Genesis 9 would helkp, but I suspect the base issue is that a product you have installed has messed up the basic Gensis 8 metadata (not, sadly, an unknown occurence). Try reinstalling Genesis 8 Starter Essentials.
    How are you installing content and are you logging in to DS?
    I manually install and fire up install manager once in a while to check for updates - I am not logged in when using DS, and Richard I have reinstalled G8 Starter Essentials.. The weird thing is that loading a G9 fixes it every time
    Have you refreshed (don't remember the actual command) the metadata in the database after you reinstalled the Genesis 8 Starter Essentials?
    Nice one - will try that
    Alas, refreshing metadata had no effect
  • RTry reimporting metadata - Content Library option menu (the lined button in the top corner, orr ight-click the tab), select Content DB Maintenance, check reimport Metadata, and in the enxt window check Genesis 8 Starter Essentials (I guess you are doing this anyway if you install manually).
    Unfortunately this does nothing to eliminate the problem. I guess I will have to keep trying "stuff" - worst case scenario do a complete re-install with clean content directories as well. Dread this though, as I have A LOT of non-Daz assets :(
    Update: Found a solution!
    Replaced the default files with the alternative templates found here:
    https://www.daz3d.com/forums/discussion/602891/alternative-powerpose-templates-genesis-1-2-3-8-8-1-9/p1
