Some Studio 4.8.x UI questions
Hi, I'm hoping someone has figured out how to do a few things that I don't seem to be able to make happen:
1) Is there a way to reorder parameters in the pose/shaping tabs and save the order? I can't figure out how to change the order.
2) Is there a way to force the parameters not to use large icons for display? I just want the name and numbers, I don't need the icons.
3) Is there a way to select multiple parameters and change their values all at once? I've tried ctrl-clicking etc., but no luck.
Any help appreciated.
  • srieschsriesch Posts: 4,243
    3): which parameters, under what situation?  If for example you want to select two objects and use the "X Translate" parameter on both, if you go to the Parameters menu and select "consolidate properties", then you will have a single parameter slider that affects both at once.  You can do the same thing with the surfaces, although you have to select both surfaces first of course.  Presumably that only works with multiple objects that have a parameter with the same name.
  • fixmypcmikefixmypcmike Posts: 19,718
    2) Use the Parameters pane instead of the Shaping/Posing panes
  • Gr00vusGr00vus Posts: 372
    For example, I have the muscle morphs for G2F. I'd like to be able to select multiple morph parameters (biceps, triceps, delts, etc.) and dial them all to a particular number all at once. As it is now I have to go to each one and set it separately. There's got to be a better way to do that.
    This is gold - GOLD!  Thanks.
