About Grillz for Genesis 8 Have picture before render and after
Hey everyone what's up :)
I have some question , I want to make the teeth with the diamond and gold in the sides and I did it , But for some reason when I render the picture its back to silver..
Any one maybe know why and can help me with that?
Thanks!
739 x 494 - 1M
1522 x 849 - 4M
  • felisfelis Posts: 6,503
    edited February 2023
    Did you use a shader for the gold, and if which shader?
    And if not, how did you set the gold?
    Edit: I realised it is a product you are using, so I assume the surface material should be ok. Your render has a very faint yellowish. What type of lighting are you using?
    Post edited by felis on
  • crosswindcrosswind Posts: 10,249
    It seems that you either used a wrong shader or just set a wrong color to the metal surface ~ Check the metal surface in Surfaces tab, if Base Color is gray or sth., change it to yellow ~~ or reshade it correctly~
    Post edited by crosswind on
    Thanks it's working , I just needed to click the Grillz and then put gold teeth and its worked out :)
    @crosswind It's worked out at the end thanks!
