GPU Failing [RESOLVED]
MrRogerSmithMrRogerSmith Posts: 175
EDIT: It seems the scene I was working with had some specific issue with it.  I couldn't figure out what it was, so I just scrapped the scene and started over.
Hello, wondering if anyone can point me in the right direction with this GPU error.
My renders are failing just as soon as they start and I'm getting a GPU error message.  I haven't changed any settings lately, everything was working fine one moment and the next it wasn't.
I tried downloading the latest driver from Nvidia's website but it didn't change anything.  I've attached my full log as a txt file, here's what it says:
2023-02-07 17:26:37.178 [INFO] :: Loaded image: SH2207_FullWhite.jpg
2023-02-07 17:26:37.552 [INFO] :: Loaded image: SH2207_FullWhite.jpg
2023-02-07 17:26:55.473 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "E:\Daz 3D\Applications\Data\DAZ 3D\My DAZ 3D Library\Runtime\Textures\DimensionTheory\iRadiance\SkiesOfIradiance\DTSoI-SunnyH.hdr", no selector, pixel type "Rgb_fp", 8192x4096x1 pixels, 1 miplevel.
2023-02-07 17:27:00.939 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry.
2023-02-07 17:27:00.940 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating motion transforms.
2023-02-07 17:27:00.941 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing scene graph.
2023-02-07 17:27:00.941 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing geometry for motion time 0
2023-02-07 17:27:00.987 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [WARNING] - TRIT:GEOMETRY ::   1.0   TRIT   geo  warn : Object DS_shape_980_3030: the parametric approximation level is set to 4. The original value of 5 would produce too much geometry in a single mesh.
2023-02-07 17:27:01.498 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [WARNING] - TRIT:GEOMETRY ::   1.0   TRIT   geo  warn : Object DS_shape_98c_3130: the parametric approximation level is set to 4. The original value of 5 would produce too much geometry in a single mesh.
2023-02-07 17:27:02.092 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [WARNING] - TRIT:GEOMETRY ::   1.0   TRIT   geo  warn : Object DS_shape_9c7_3587: the parametric approximation level is set to 5. The original value of 6 would produce too much geometry in a single mesh.
2023-02-07 17:27:14.694 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Geometry import (1 triangle object with 62 M triangles, 0 fiber objects with 0 fibers (0 segments), 1 triangle instance yielding 62 M triangles, 0 fiber instances yielding 0 segments) took 13.749 s
2023-02-07 17:27:14.695 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating section objects.
2023-02-07 17:27:14.700 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating materials.
2023-02-07 17:27:15.660 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 879 textures, 0 lambdas (0 unique)
2023-02-07 17:27:15.691 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Computing 3 flux compensation factors took 0.001 s
2023-02-07 17:27:15.692 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Emitter geometry import (16 light sources with 35174 triangles, 1 instance) took 0.004 s
2023-02-07 17:27:15.694 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating volumes.
2023-02-07 17:27:15.694 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment.
2023-02-07 17:27:16.642 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lens.
2023-02-07 17:27:16.643 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
2023-02-07 17:27:16.643 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
2023-02-07 17:27:16.643 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate.
2023-02-07 17:27:16.644 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating caustic portals.
2023-02-07 17:27:16.644 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
2023-02-07 17:27:16.662 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using no convergence estimate.
2023-02-07 17:27:16.665 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
2023-02-07 17:27:16.671 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using batch scheduling, caustic sampler enabled
2023-02-07 17:27:16.671 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing local rendering.
2023-02-07 17:27:16.690 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using OptiX version 7.3.0
2023-02-07 17:27:16.735 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing OptiX for CUDA device 0
2023-02-07 17:27:18.137 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):
2023-02-07 17:27:18.137 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info :     CUDA device 0 (NVIDIA GeForce RTX 3090)
2023-02-07 17:27:18.137 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
2023-02-07 17:27:18.138 Iray [INFO] - IRAY:RENDER ::   1.10  IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): Processing scene...
2023-02-07 17:27:26.441 Iray [INFO] - IRAY:RENDER ::   1.12  IRAY   rend info : Importing lights for motion time 0
2023-02-07 17:27:26.444 Iray [INFO] - IRAY:RENDER ::   1.12  IRAY   rend info : Initializing light hierarchy.
2023-02-07 17:27:26.578 Iray [INFO] - IRAY:RENDER ::   1.12  IRAY   rend info : Light hierarchy initialization took 0.133 s
2023-02-07 17:27:28.057 Iray [INFO] - IRAY:RENDER ::   1.10  IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3090): Scene processed in 9.919s
2023-02-07 17:27:28.062 Iray [INFO] - IRAY:RENDER ::   1.10  IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3090): Allocated 84.377 MiB for frame buffer
2023-02-07 17:27:28.067 Iray [INFO] - IRAY:RENDER ::   1.10  IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3090): Allocated 1.906 GiB of work space (2048k active samples in 0.004s)
2023-02-07 17:27:28.068 Iray [INFO] - IRAY:RENDER ::   1.10  IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3090): Optimizing for cooperative usage (performance could be sacrificed)
2023-02-07 17:27:28.498 Iray [INFO] - IRAY:RENDER ::   1.10  IRAY   rend info : Allocating 1-layer frame buffer
2023-02-07 17:27:28.571 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00001 iterations after 10.434s.
2023-02-07 17:27:28.875 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00002 iterations after 10.738s.
2023-02-07 17:27:29.485 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00004 iterations after 11.349s.
2023-02-07 17:27:32.859 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER ::   1.8   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): the launch timed out and was terminated (while launching CUDA renderer in <internal>:937)
2023-02-07 17:27:32.860 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER ::   1.8   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): Failed to launch renderer
2023-02-07 17:27:32.860 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER ::   1.10  IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): Device failed while rendering
2023-02-07 17:27:32.862 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [WARNING] - IRAY:RENDER ::   1.10  IRAY   rend warn : CUDA device 0 (NVIDIA GeForce RTX 3090) is no longer available for rendering.
2023-02-07 17:27:32.865 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [WARNING] - IRAY:RENDER ::   1.10  IRAY   rend warn : All available GPUs failed.
2023-02-07 17:27:32.866 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER ::   1.10  IRAY   rend error: Fallback to CPU not allowed.
2023-02-07 17:27:32.866 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER ::   1.10  IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): the launch timed out and was terminated (while initializing memory buffer)
2023-02-07 17:27:32.867 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER ::   1.10  IRAY   rend error: All workers failed: aborting render
2023-02-07 17:27:32.867 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER ::   1.10  IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): the launch timed out and was terminated (while de-allocating memory)
2023-02-07 17:27:32.868 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER ::   1.10  IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): the launch timed out and was terminated (while de-allocating memory)
2023-02-07 17:27:32.869 [ERROR] Iray :: Internal rendering error.
2023-02-07 17:27:33.227 [INFO] :: Saved image: C:\Users\MrRog\AppData\Roaming\DAZ 3D\Studio4\temp\render\r.png
2023-02-07 17:27:33.243 [INFO] :: Finished Rendering
2023-02-07 17:27:33.563 [INFO] :: Total Rendering Time: 1 minutes 16.61 seconds
2023-02-07 17:27:40.507 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
2023-02-07 17:27:40.507 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3090): 4 iterations, 11.443s init, 4.738s render
2023-02-07 17:27:40.508 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): the launch timed out and was terminated (while de-allocating memory)
2023-02-07 17:27:41.341 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - OPTX:RENDER ::   1.18  OPTX   rend error: Error synching on OptixPipeline event (CUDA error string: the launch timed out and was terminated, CUDA error code: 702)
2023-02-07 17:27:41.342 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - OPTX:RENDER ::   1.18  OPTX   rend error: Error destroying OptixPipeline event (CUDA error string: the launch timed out and was terminated, CUDA error code: 702)
2023-02-07 17:27:41.344 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER ::   1.18  IRAY   rend error: optixPipelineDestroy(pop_ptr(m_pipeline)) failed: CUDA error
2023-02-07 17:27:41.344 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - OPTX:RENDER ::   1.18  OPTX   rend error: Error synching on OptixPipeline event (CUDA error string: the launch timed out and was terminated, CUDA error code: 702)
2023-02-07 17:27:41.345 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - OPTX:RENDER ::   1.18  OPTX   rend error: Error destroying OptixPipeline event (CUDA error string: the launch timed out and was terminated, CUDA error code: 702)
2023-02-07 17:27:41.345 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER ::   1.18  IRAY   rend error: optixPipelineDestroy(pop_ptr(m_pipeline)) failed: CUDA error
2023-02-07 17:27:41.345 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - OPTX:RENDER ::   1.18  OPTX   rend error: Error synching on OptixPipeline event (CUDA error string: the launch timed out and was terminated, CUDA error code: 702)
2023-02-07 17:27:41.346 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - OPTX:RENDER ::   1.18  OPTX   rend error: Error synching on OptixPipeline event (CUDA error string: the launch timed out and was terminated, CUDA error code: 702)
2023-02-07 17:27:41.346 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - OPTX:RENDER ::   1.18  OPTX   rend error: Error destroying OptixPipeline event (CUDA error string: the launch timed out and was terminated, CUDA error code: 702)
2023-02-07 17:27:41.346 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER ::   1.18  IRAY   rend error: optixPipelineDestroy(pop_ptr(m_pipeline)) failed: CUDA error
2023-02-07 17:27:41.347 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - OPTX:RENDER ::   1.18  OPTX   rend error: Error destroying OptixPipeline event (CUDA error string: the launch timed out and was terminated, CUDA error code: 702)
2023-02-07 17:27:41.347 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER ::   1.18  IRAY   rend error: optixPipelineDestroy(pop_ptr(m_pipeline)) failed: CUDA error
2023-02-07 17:27:41.347 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - OPTX:RENDER ::   1.18  OPTX   rend error: Error synching on OptixPipeline event (CUDA error string: the launch timed out and was terminated, CUDA error code: 702)
txt
txt
log.txt
4M
Post edited by MrRogerSmith on
