Obj export mirrored in Blender
I exported a posed figure out of Daz. But when I import it into
Blender it is mirrored.  For example, in Daz the left hand is gripping a prop, but
in Blender the right hand is doing it because the whole model has been mirrored.
Anyone know a solution for this?
  • Also I forgot to mention that I exported it out of DAZ as an OBJ.
  • The export options dialogue is set to mirror the X axis by the sound of it. Theer is a Blender preset, but I believe its settings are wrong for the current version of Blender - try using the native DAZ Studio preset (1 unit = 1cm), the Lightwave/modo preset (1 unit =1m) and if those have the figure laying down try the 3DStudio Max preset.
    506 x 319 - 32K
    Yes, the preset Blender export is incorrect, but it is which axis that is up, that is the usual 'wrong' part.
  • Here's a Blender to Daz (and back again) tutorial that address both the size and placement problem.  I hope it helps and I always welcome comments.
    Bob
    pdf
    pdf
    Blender to Daz3D (August 2015).pdf
    967K
  • Once you have settings that work in the OBJ dialogue use the Save Preset button to make a new Blender 2015 (or whatever you want to call it) preset, then you can set the correct values in and out simply by selecting that.
  • StratDragonStratDragon Posts: 3,289
    Bob
    this is cool! thanks for the documentation.
