Mirroring JCMs from Left to Right
Is there a way to mirror JCMs which have been set up on the Left side of a figure to the Right side?
  • crosswindcrosswind Posts: 10,358
    edited January 2023
    You may use mcasual's mcjMirrorMorph script to mirror a JCM. Not fast but accurate, then you need to do ERC freeze by yourself:
    https://sites.google.com/site/mcasualsdazscripts5/mcjmirrormorph
    Post edited by crosswind on
  • lilweeplilweep Posts: 2,883
    crosswind said:
    You may use mcasual's mcjMirrorMorph script to mirror a JCM. Not fast but could be done~
     By the looks of things, that script will just make a symmetrical morph on either side, but it wont set up the JCM's ERC links.  So... if i have to do each morph separately and still have to create all JCM links anyway then might as well just do it using Morph Loader Pro mirror options.
    edited January 2023
    The mirrored import thru Morph Loader Pro cannot automatically create the ERC link and needed controller either, you still have to manually set up one by one~
    never said otherwise.
    Would have thought someone would have implemented this feature over the years, as would save a lot of work.
