• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz 3D Forums > 3rd Party Software > Cinema 4D Discussion
Daz to Cinema 4D Bridge - the mouth opens askew
coco_pernoudcoco_pernoud Posts: 3
January 2023 in Cinema 4D Discussion
Hello everybody
Does anyone have the same problem as me?
when I transfer a genesis 8.1 character from Daz to C4D
everything is going well, but when I want to make him open his mouth (jaw open) , on C4D the mouth opens crookedly. On Daz it is ok.
See the file attach.
I do not understand why. What can i do? thanks
I am on a mac studio and C4D 23
4169 x 3800 - 730K
  • coco_pernoudcoco_pernoud Posts: 3
    January 2023 edited January 2023
    There is a problem on the mouth and when i blink the eyes. I think the eyes blink crookedly too, but as the movement is small, it is not very visible... See the file, on Daz or on C4D the blink of the two eyes are the same : 90% around
    The squint for eyes is good
    Eye wide left or right is not good to
    The mouth control is good
    And when i use the "Connect Genesis 8.1 to moves by maxon" the head turns good, the eyes looks good too (good direction.... ).
    1568 x 1138 - 115K
    Post edited by coco_pernoud on January 2023
  • uarrutiuarruti Posts: 0
    February 2023
    Hi,
    The same happened to me. Do you fix the problem?
  • t.montepolit.montepoli Posts: 0
    April 2023
    Same problem here. There is a weird rotation on the posemorph of the jaw bone that should not be there (as far as I understand).
    Tried to modify the xpresso setup but couldn't find a proper solution.
  • oliphantscottoliphantscott Posts: 1
    May 2023
    did anybody figure this out yet? having same issue
  • antoneart_5b5de25eb1antoneart_5b5de25eb1 Posts: 2
    May 2023
    I'm having the same issue, anyone figured out a solution?
    July 2023
    FOUND A SOLUTION!!!
    just download the source code from get hub and manually update the files in the c4d plugin folder AND the daz3D plugin folder and the issue is solved!
    Releases · daz3d/DazToC4D (github.com)
  • HathoresHathores Posts: 0
    August 2023
    antoneart_5b5de25eb1 said:
    FOUND A SOLUTION!!!
    Hello! I tried to download as far as the past three as you said with no success. I would delete the c4d plugin folder, put the source code as explained on the github inside the \Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\plugins and then in Daz inside the plugin I'd reinstal the c4d through the export in advanced settings and install plugin. Am I doing it wrong?
  • GordigGordig Posts: 10,811
    February 2024 edited February 2024
    I hadn't bridged a character in quite a while, so I forgot about this issue. It's still there for me, and installing directly not only doesn't completely solve the problem, but makes some things worse. What makes the biggest difference is disabling the XPresso tag on the morph controller group and just controlling morphs through the pose morph tag on the figure mesh. The culprit appears to be some of the math nodes in the morph controller XPresso soup, because if you disable that XPresso tag and activate, for example, jaw open on the figure's pose morph tag, it works as expected.
    Here's the jaw open morph as controlled from the morph controller:
    And with the morph controller disabled, driven from the figure's pose morph tag:
    You can also see the skeleton not aligned with the mesh, which is a problem I wasn't having before.
    629 x 511 - 424K
    630 x 513 - 433K
    Post edited by Gordig on February 2024
    February 2024
    I've spent a LOT of time over the last week trying to figure out the best way to set Daz figures up in C4D. Right now, the best approach seems to be starting with a bridged figure with no morphs, just to get the joints properly aligned. I've also noticed that the bridge doesn't actually send over all the morphs you select (I only get about four correctives and five or six expressions), and a lot of the morphs that do make it over seem to be improperly exported, like the expressions are muted, so I also export the figure as FBX with all pJCMs and facs, then painstakingly wire everything together myself in a new XPresso tag. If the bridged figure actually brought all the morphs over, it would be a simple matter (though still quite a hassle to sift through the hundreds of nodes) to track down the math nodes that are causing the jaw to go haywire.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
