Does Skin Builder 8 for Genesis 8 Female work with Genesis 8.1? (Solved: It doesn't)
BlueFingersBlueFingers Posts: 924
edited January 2023 in The Commons
There is currently a really good deal on Skin Builder 8 for Genesis 8 Female, but does it work correctly on Genesis 8.1? I'm not sure as the surfaces have been changed between the two generations.
Post edited by BlueFingers on
  • Matt_CastleMatt_Castle Posts: 3,300
    Not directly, no. The two main limits are:
    - The script itself will not run with G8.1 selected.
    - It only supports the base Genesis 8.0 Female UV set.
    While you could process skins using that UV on on G8.0 first and then transfer them to G8.1, the product cannot be said to fully support G8.1 Female.
  • Ah that is too bad as I wanted to use it on G8.1 skins. Thanks for letting me know!
