Does anyone know how to modify .gfa files?
geoff6geoff6 Posts: 250
Hi all,
Can anyone point me in the direction of some software that can open and save  a .gfa file? Iwant try modifying one.
Thnaks in advance.
g
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,493
    edited August 2015
    Animate 2
    the DAZ studio plugin by gofigure
    it makes animate lite editable
  • geoff6geoff6 Posts: 250
    Hi JaguarElla,
    Thanks for that and I am using Animate 2 however, the .gfa I want to modify is itself a modifier which I want to adjust. It is a one time adjustment rather than having to go through and correct each froma which is my only (known) alternative.
    Thanks again,
    g
  • larsmidnattlarsmidnatt Posts: 4,511
    edited August 2015
    you can make a new aniblock with the offset you need. For example I use V4 aniblocks on Genesis/Genesis 2. In order to do this I make a single frame Aniblock to correct the pose difference from V4 to G1 or G2. I add this block to it's own layer. I forget the exact setting to use, but I think you set that layer to additive(not override!). it will add that offset to the existing animation.
    You don't need to edit the existing GFA, you can make the adjustment by having the two animations on different layers.
    If you wanted to update an adjustment aniblock I guess you could follow that concept, bake the two blocks to keyframes and then save those new DS keys as a new aniblock that can be used as an offset.
    Post edited by larsmidnatt on
    Genius.
    That did the trick, thankyou very much. Now there is no end to what I can do...
    Tomorrow, the world!
    G
    Indeed! Good luck.
