Forest house - two questions
HeraHera Posts: 1,972
I have two question about this product: Forest House | Daz 3D
1. The furnitures and other props aren't listed in the 'What's Included' so I assume they are not included. How about the kitchen appliances and the fireplace?
2. The building seems to come without a bathroom, right?
  • The fireplace has a light On/Off material state given, so I would read that as the fireplace being present. I'd be astonished if the built-in kitchen isn't included. As for the other furniture - it's not mentioned so may not be there. But it may be.. insufficient information. It's why I like the clay renders that DAZ used to insist on so you got to see exactly what's there. If you like it enough to get it without furniture & then find it has, I suspect you'd be pleased.
    As for the second question.. I think you may be correct, and your characters will find out an answer to the age old question about bears. There doesn't seem to be space anywhere for a WC in the layout visible.
    Regards,
    Richard.
  • felisfelis Posts: 6,597
    Funny. I was thinking the same when I saw the house with full size windows all the way round - where is the toilet...
  • SevrinSevrin Posts: 6,314
     That's where the "forest" part of the "Forest House" comes in.
    Remember boots, in case of rain or snow.
  • TimbalesTimbales Posts: 2,456
    It seems to be based on the historic Edith Farnsworth House, designed by Mies van der Rohe. It's a US National Historic Landmark. https://edithfarnsworthhouse.org/ There are two bathrooms in the real house, located in the central module that has the kitchen on one side and fireplace on the other.
    http://docs.daz3d.com/doku.php/public/read_me/index/88716/file_list
    Does seem to have at least some furniture like a bed, bed cover, bedroom chair, bedroom table etc The items can be found listed under "/data/human/Forest House S/..."
  • FirstBastionFirstBastion Posts: 8,085
    Can always build an outhouse. Or borrow one.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,734
    add a railing to the pier
    There are props included - see attached list.
    There is no bathroom only a somewhat-narrow void where a bathroom should be. I suppose if you bring a sledgehammer to knock through the wall and bring some other assets with you then you can probably squeeze one in there.
    480 x 886 - 297K
