Render the shadows but not the object?
DekeDeke Posts: 1,636
Is there a way? I like to render in layers for post effects, but that means I'm missing on the shadows cast by one layer onto another.
  • srieschsriesch Posts: 4,243
    If you are using the 3Delight render engine, and don't need to use a specific shader:
        To stop a whole item from casting shadows, just click off the Cast shadows property in the Parameters pane.  To hide the object but still have it cast shadows, select the surface of the object to hide, double-click on !UberSurface Base.duf, then in the parameters pane set the "Fantom" property to "On".
