How do I permanently disable drag to move model node feature in daz?
How do I permanently disable drag to move feature in daz? The one where you click on a node like an arm, finger and drag to move the limb.
This by far is the most useless and annoying feature in daz, for example if there is any computational lag when you just want to select a node like the arm, it decides to move the arm but since it moved the arm it has to calculate the position of the rest of the body and then I have to undo which introduces more computation lag.
I want to disable the feature so when I click and drag any node limb on a model nothing happens.
If you pose using the sliders you could use the Node Selection tool, or Edit>Figure>Inverse Kinematics>Enable IK off (ctrl k).
