Find all uses of a texture map?
I've been searching around but I can't seem to find this. Is there a way to find all the uses of a particular texture in a Daz Studio scene? Say I've got a model that uses "metal_floor_1_diff.jpg" on multiple surfaces, and I've kitbashed in a 2nd model then applied the same texture to multiple surfaces there. So now there are 2 models using "metal_floor_1_diff.jpg" on multiple surfaces. Is there a function or script to list out all the uses of that JPG file in the scene? (Ideally not just for one JPEG, but for all of them. Base, glossy, bump, normal, etc.) Thanks!
  • felisfelis Posts: 6,558
    If you save it as a scene, you can search through that.
    But I am not aware of any methods inside Daz Studio.
  • IceCrMnIceCrMn Posts: 2,334
    Activate the Surface Selection tool and right click on the surface that has the map you want to search for and select
    "Select All surfaces using Diffuse Color map"
    from the list.
    and it should alread have the map you wanted to look for listed if you clicked the correct surface.
    Then on the Sufraces pane all those surfaces using that map will be selected for you.
    Lots of other ways to search on that list also if it's not the diffuse color map you want to look for.
  • jim_doriajim_doria Posts: 133
    @IceCrMn Perfect! Thanks so much. @felis I'll keep the scene file in mind as a plan B. Thanks!
