Help! One single property missing (Right Shoulder Twist)
Hello
From one day to another I miss a property in Genesis 8 Male: Right Shoulder, Twist
I reinstalled Genesis 8 Male Starter, but nothing changed. When I look in the property Editor, I see (compared to the left shoulder) that there's an alias missing: XRotate 2 (Twist). But I don't have a clue how I can restore this on the right shoulder? I appreciate your help!
Thanks in advance.
  • felisfelis Posts: 6,559
    Have you hidden properties enabled?
    Try if you can show a screenshot of what you are seeing.
  • Hiho, thanks for your help.
    Unfortunately nothing is hidden. But as desperated as I am, I found out what the problem was, more or less. There is this folder in "user\Roaming\DAZ 3D\dson\cache\data", which "survived" all de- and reinstallations. So I deleted it manually and TATAA!, problem solved. Don't have a clue why, some data seemed to be stored there and caused the problem.
  • The DSON Cache can also becleared through Edit>Preferences. Uninstalling will not, and should not, affect settings or user data - it is rarely the fix for issues (generally only if a core application file has been damaged or lost).
  • Hi Richard,
    Thanks for the explanations!
