Reset Object(prop) coordinates after unparenting
I've got a couple of prop/objects, that have gone through multiple parenting to figures, etc.
I want to get them reset, but they seem to retain the old positioning data....even after parenting to "NONE"
For example, a sphere is at around x=3, but the X-translate shows 0.1?!?! I checked the origin, and it is at around 3...why would it still read 0.1 even after uparented? (I could understand, perhaps it was 0.1 off its parent, which may have been around 2.9...but...I am out of ideas?)
Post edited by 3dOutlaw on
What is at 3 and what is at .1? Do you have Parent in Place checked in the Change Parent dialogue, if you are using that, or the Scene pane option menu, if you just drag-and-drop?
Yes, I do have Parent in Place checked...
I typically just drag an drop, but I did use the option instead to see if that fixed it.
Those objects read 0.1...but how I know it is 3, is that I made another new prmitive sphere, moved/scaled it to sit directly on top of that object, and it was at 3.
Are you sure the item isn't scaled, and was modelled at the origin?
