Putting 3rd party stuff in Daz 4.21
TheCastellanTheCastellan Posts: 711
edited January 2023 in The Commons
[Putting 3rd party stuff in Daz 4.21] HOW does one do it?   SOME work, but many give error messages and all I get on screen is big, grey blocks.
Help? indecision
    The grey boxes will be because the files are not in the correct place - which is most likely because some 3rd party products are packaged poorly.
    I always use Content Wizard to install non-Dazstore stuff which doesn't always handle the 3rd-party stuff perfectly but does help quite a bit.
    However, if you are doing it manually you just need to make sure you correctly merge the product folders (be careful not to replace when dragging and dropping as that would be bad) to the correct place. e.g. If the 3rd party product has a "Content" folder then ignore that and just use the folders inside - likewise if they have Vanity folders or a "My Library" folder you should ignore those and use the folders inside.
  • Cris PalominoCris Palomino Posts: 13,053
    What types of files are you using? OBJs? Meshes, textures? We need more information from you.
