Iray Optimized Genesis 3 Female MAT
Kerya
in The Commons
Is there one? Where can I find the file?
I found the one for the Genesis2Female in People\Genesis 2 Female\Materials\Iray - but there is none for Genesis3?
But the G3F base? She loads with AOA Subsurface Shaders - so is not fit to be rendered in Iray, obviously ...
*puzzled why the newest doll is not available for the newest toy (render engine)*
just switch switch the surfaces to iray in the surface tab just look through the preset data for the iray shader.
then if you wanted to you can copy and paste the surface date of a different genesis 3 actors presets and switch the texture images back Manually
