How can I install an older version of Studio?
I installed the latest and now everything is filed differently and I liked the older version better. Any old copies around?
  • LeanaLeana Posts: 13,593
    Older versions are not available for download.
    If you don't have a backup of the install files for the version you want to reinstall, you can try contacting support to see if they can provide you with them but there's zero guarantee they will.
  • AFAIK reinstalling any other edition is not going to bring back lost filing setups.
  • How is the filing different? A Daz Studio update shouldn't affect content directories or most aspects of accessing the content.
  • I don't know. The stuff is all different now. I used to be able to see the Michael Skeleton under the Michael tab under People or whatever but now there is just puppeteer and little else. I don't know how to explain it but when I click on places where stuff was it ain't now.
    edited January 2023
    Oh it's been years, if I recall correctly that puppeteer information was not put where all the other Michael stuff was.
    One way to find out where something was put, is to manually download a zip and unzip it. Check the folder structure. Then locate the already installed content via the Content Pane following the same trail.
    If it is still not locable, then check the Content Directory Manager - that the correct pathways exist for Poser and D/S content.
    Post edited by Catherine3678ab on
  • Which pane are you looking in, and which cotnainer with if it is the Content Library (Daz Studio Formats/Poser Formats/Categories/Products) or tab if it is the Smart Content pane (Files or products at the top, install states along the bottom).
