Can yall help me, I have a little problem with my color?
GunGun Posts: 52
Today, I had tried use skin color and face color for my genis 2, but maybe I did something wrong, so after render my character become back. I use light brown skin for my genis skin. If anyone know, please tell me know.
Thanks you for listening.
600 x 600 - 562K
  • NovicaNovica Posts: 23,925
    Are you familiar with the Surface pane? If you select your Genesis over in Scene, and click on the Surface tool above the viewport (looks like 3 pieces of paper) you can go into the Surface pane and individually select which parts of the character you want to tweak. You want to change the Diffuse color first and see what that does, then twiddle with the other sections where you see colors (Specular, for example, and Ambient)
    Also your lights impact how it will look. Do you have enough lights on the scene? Are you using white or whitish blue? So I'd say change your skin surfaces, add more lights, and be sure your lights are bright enough and the right color.
  • GunGun Posts: 52
    Thanks Novica, I ll try again.
