How to use Genesis3 Female Merchant Resource?
Ck377Ck377 Posts: 17
Well I download Genesis3 Female Merchant Resource,But after install I can't find
it in software..
So I open the download files,I found that all files are tif.
someone can tell me how to use that?
  • Cris PalominoCris Palomino Posts: 12,964
    http://www.daz3d.com/genesis-3-female-merchant-resource does indicate that you are being given TIF files.  These are textures that you can use to produce your textures for characters, as the description says, and may not be used for freebies/give-aways.
    You can add these textures to a G3 Female through the surfaces tabs.  The TIF files can be opened in Photoshop, or other image editor, to change or add to so that you make a texture that is uniquely yours.
  • Ck377Ck377 Posts: 17
    Thanks for your replying! I understand I need to use those tif files to change original G3 female textures.
    But where I can find the original G3 female tex files? I look for all of daz3d filepackage and I can't find them.
  • larsmidnattlarsmidnatt Posts: 4,511
    edited August 2015
    You wouldn't touch the original G3 textures. Just apply these textures to the character in the needed slot.
    Don't hunt for the original textures :) What you should do is have the merchant resources in a folder you know, and reference them in the proper surface slots for the figure. I would suggest you actually make a copy that you will modify so you can always go back to the original if you want to make a new characater skin.
    Post edited by larsmidnatt on
