Problem with easy pants and Dforce hips.
So I'm trying to use the easy pants geoshell product with dforce hips and I can't seem to make it not look white. I've made things like this work before by hiding certain shell spots but it doesnt work for this.
  • Matt_CastleMatt_Castle Posts: 3,257
    Hameleon's "Easy X" products all use specialised UVs that will not be available to any geograft, and therefore not to any geoshell over the grafted area; these parts will not work together properly by default..
    Your three options are:
    - If you know how to transfer UVs in a program such as Blender, do so to provide the geograft the correct UVs for the geoshell.
    - Bake the textures for the Easy Pants back onto the default UVs using map transfer in order to make them compatible with the graft
    - Simulate the hips, bake that to a morph, then transfer the morph back onto the figure in order that the graft is no longer necessary.
