What software do I use to create lip-syncing animation for M4?
I'm using M4 for an animation project and need to create some talking. Any suggestions?
  • Arnold CArnold C Posts: 740
    DAZ Studio's 32 bit versions come with the the "Lip Synch" plugin (unfortunately 64 bit doesn't have it). You can use pre-recored audio in wave format in it. If you want to use Iray, you can prepare your animations within the 32 bit version, then save your project and switch to the 64 bit version to render it there.
    1024 x 728 - 145K
  • IvyIvy Posts: 7,165
    edited August 2015
    That is what I do too.  is make my lip synce in the 32 byte version then save it and then open it in the 64 byte version for rendering
    Post edited by Ivy on
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,712
    if in Platinum Club this is cheap
    http://www.daz3d.com/mimic-lite
    you export a pz2 file you load as a pose
