GTX970 - TITAN X speed test rendering for IRAY
My config i7 2600k + 32 Go + PCI express 2.0 motherboard. MSI GTX970 (4 Go, 1664 Cuda) main GPU, MSI TITAN X (12Go, 3072 Cuda) secondary GPU
Test 1: scene : Victoria 6 + Skyler hair : Iray material for both. Environment map + headlamp. The scene weight is 2 Go. Render Time 1 minute. OptiX prim ON
CPU : 85 iteration.
GTX 970 : 700 iterations
Titan X : 1067 Iterations
GTX970 + Titan X : 1460 iterations
CPU + GTX970 + Titan X : 1136 iterations.
Test 2 : Scene test : Pursuit on my gallerie. The scene weight is 5 Go, impossible to render with the GTX970. Firefly + Bloom + Noise filter, quality 2. Render time 3 minutes. OptiX prim ON
Titan X : 262 iterations
GTX970 + Titan X : 348 iterations but the memory usage is absurd : 4Go on the GTX, 8 GO on the Titan X.
Conclusion.
The CPU is useless. The best option is to use 2 GPU. the number of CUDA is important but the gain is not linear
 My intention was to use the GTX for the viewport and the Titan X for rendering.
  • IceCrMnIceCrMn Posts: 2,334
    Did you happen to save those renders so we can see them for comparison?
  • nicsttnicstt Posts: 11,715
    I almost always get better results with just my render card selected for rendering; if selecting anything else ever has made a difference, then it was very small positive but potentially more detrimental. It also increases heat and noise another negative for me. I like quiet. :)
    OptiX seems pointless at best.
    Anyone actually know what it is supposed to do?
  • JPiatJPiat Posts: 71
    None are finished... The idea is to compare the number of iterations after the same period of time using different configuration.
    The default setting 5 000 iterations is not that bad. I use 18 000 iterations on most of my render.
