Practical difference between Focal Width and Focal Distance?
Hi all,
I was playing around with getting a wider shot yesterday and found that these two options do roughly the same thing. Narrow or widen the shot. I tried rendering the scene by adjusting one of each and checking for differences and I didn't really see one.
What is the difference?
  • Do you mean Frame Width? That has its most noticeable effect when you have a very wide aspect to your camera - try setting the aspect ratio to 10:1 and then experiment with the Frame Width setting, noticing how the behaviour of the perspective changes. This is a new feature added as people were having problems getting acceptable results with widescreen renders.
  • glaseyeglaseye Posts: 1,312
    edited August 2015
    Erm, I take it you're talking about frame width and focal length; focal distance is used for the distance between the object and the camera lens (for use with depth of field)
    Frame width would be the size of the negative on a rol of film (remember those wink) most commonly 36x24mm, hence the default value of 36 (nowadays that would be sensor size smiley)
    The focal length would be the convergence point for the camera lens, usually the 'base' lens would be about 50-55mm for the above mentioned camera (shorter for most digital cameras)
    So, a wider frame widht with the same focal length gives a wider view (Field of view), In rendering it makes the biggest difference when you use depth of field. longer focal length gives a smaller 'depth area' were the image will be in focus.
    LoL, Richard beat me to it (didn't get a notice as I would in the old forum....)
    Post edited by glaseye on
