How to improve pixelated clothes
As the attached image shown, I often encounter pixelated clothes, especially between shaded and non-shaded area. I wonder why this happens and how this can be avoided.
I thought it's because of low resolution in texture (e.g., 1000x1000). But making texture in higher resolution (2000x2000) didn't help much.
Any help or clue would be appreciated.
361 x 299 - 246K
  • Posting the question made me experiment more and eventually found that I could reduce the pixelation by adjusting tiles.
  • felisfelis Posts: 6,644
    If it is the shadows you are concerned about, you can try to up subD, or if the clothing isn't subD already apply it.
  • With the shadows, that looks like either a shadow terminator issue (if using low poly), in which case, as felis states, add / increase sub_d. Or, I have seen similer issues when using some bump/normal maps. (try removing bump/normal maps to check).
