Delating Morphs
ExperimenterExperimenter Posts: 167
I have a problem to delate my morphs.
I play with G3F and created a few morphs for my own. The morphs have a problem other morphs were activeted by saving. Now I want to delate the problemmorphs but how. Following methodes I tried;
  • Delate the saved morphs from the data folder and later the full file "Library-data-DAZ 3D-Genesis3-Morphs-My Morphs"
  • Try to delate the morph in DAZ by the edit mode "active Edit mode-select morph by right click-select delate property" the morph is gone but when I restart DAZ the morph is there again
  • Reinstall DAZ Studio and Genesis 3 Starter Es.
Nothing work neither seperat nor all together. Everytime I start DAZ again the delated morph is there again. How can I delate my morphs?
Thank you for your help
Post edited by Experimenter on
  • Deleting the file should work - though your path looks wrong, it would be \Data\DAZ 3D\Genesis 3\Female\Morphs\Author\Product (where Author adn product are the names you enter in the option diliogue). Is it the morph that iss till there, or the non-zero values of stock morphs? If the latter it may be that you modified the stock morphs by mistake, in which case reinstalling those should fix the issue.
