How do you prevent shells from interfering with each other?
I have Breastacular and G9 Gens on one model. When Breastacular is visible, the gens material won't show up, the area is pure white. When I hide or delete Breastacular, the material shows, as though it has been there all along.
Thanks
  • felisfelis Posts: 6,604
    You have to look at all the attached geoshells, and make sure that all have a different offset.
    You can find the offset in the parameters tab.
  • FenixPhoenixFenixPhoenix Posts: 3,249
    Select the geoshell and then in the parameters tab > visibility > surfaces you can toggle off whatever isn't supported.
  • victorvictor Posts: 49
    That's it, thanks! Parameters > Shell > Visibility > WG_1_Hip was on by default.
    Thanks to you both!
    My pleasure :).
  • You can also select the shell that's on top and set the Cutout Opacity to zero on one of the shells for the afftected geograft in the material settings.
