External Harddrive?
Not sure if this should be here or Technical.  Anyhow, I am using Daz 4.7 and I have seen various posts about external runtimes.  I know it can be done, have done it myself in the past with previous versions of Daz.  What I need to know this time is in regard to the existing runtime currently in Daz My Library.  Instead of creating a new runtime, can I just move that one to the other drive on my computer? And then tell Daz where to find it? I have no problem leaving just the runtime/textures on C Drive so textures are not a problem for items installed under My Library Daz content.
621 x 606 - 79K
  • Yes, but you will need to update the CMS to point to the new location*, and the Install Manager (if you use that) won't be able to uninstall the moved products.
    * find an item in the products list in the Content Library pane, right-click on it and select Database>Edit Base paths..., set Change to All Files using this base path, select your new content directory in Change to, click Accept.
  • CybersoxCybersox Posts: 9,960
    Yes, you can move your content library or maintain multiple ones.  Keep in mind, though, that things may not run as quickly on an external drive.
  • Faeryl WomynFaeryl Womyn Posts: 3,779
    Ok Great and thanks.  For the record, it's only the runtime folder I want to move, not the my library folder, and to a second hard drive on my computer, so won't change the amount of space being used but free's up some of C Drive for my son to download and run games.
    Move the whole library or create a second one.  Otherwise products that aren't completely located in the runtimes won't be looking in the right places.
