Making Wither clothes?
MightyMiteMightyMite Posts: 96
I'm creating clothes for a Wither G8M... I exported a Wither figure and made the clothes in zBrush.  I can't get the Transfer Utility to work. The clothes keep the shape but become smaller than the figure. Does anyone know how to Transfer Utility over a character... I also tried over RAW's Massive Bulk to the same result...
Post edited by MightyMite on
  • In Transfer Utility you need to set the Source Shape to Wither, or Current if multiple morphs are used, then in the additional options, expand th dialogue using the button, you need to check reverse Source Shape from Target. As it is you are setting the clothes, mad to fit Wither, as the base shape and then DS is projecting the Wither shape into that, so the effect is doubled.
  • That seemed to work.  smileyThank you very much!
