Transfer Utility expands breast area for a shirt
Hello there,
Recently, I would like to transfer a shirt from Marvelous Designer OBJ to Daz.
The OBJ shirt was imported to Daz fine. However, the shirt was expanded around the breast area after transfered.
Please see the photo in the attachment. I've try many options in the transfer untility, and got no luck.
Any advice is highly appreciated.
- Josh
2098 x 993 - 242K
  • felisfelis Posts: 6,513
    Whch character was the clothing made on in MD, and which character are you using as source in transfer rigging?
  • Most likely you modelled the shirt around that morphed shape, and didn't set the Source Shape to the morph used (or Current if multiple were set) and enable Reverse deformations in the additional options; as a rsult DS thinks that is how the shirt should be on the base shape, and it then projects the morph into the shirt so that you get a doubled-up effect.
  • Thank you all.
    I used a G8F with breast morphed.
    As Richard suggested, the morph load works fine after I checked Reverse deformation.
    Best,
    Josh
