Surface tab
enchantedwolfe
I'm having problems with the surfaces tab, I've got one shoe (left) doing ok, but when I go to copy the surfaces to the other shoe (right) it doesn't work and I noticed that there are more stuff on one shoe (right) and not the other (left), so how can I add the extra to the other shoe (left)?
Post edited by Chohole on
In the upper left corner of the pane it lists the shader used -- you need to have the same shader on both to have the options all match.
how do I add all of the extras?
What shader is listed on the shoe with more options?
cloth, and I have no idea where that would be
Not sure, what product is it?
Mareitte outfit, the shoesw are what I'm having trouble with. I got the texturesall done except the shoes, atthe top it says that it is a cloth shader I don't even knowwhere to find that
Do you have a link to the outfit?
https://www.renderosity.com/mod/bcs/?ViewProduct=110708
Not sure why the shoes would load with different shaders -- in both cases you're loading from the DS-format People folder?
I'm making my own textures or trying to LOL
But you're loading the shoes in order to apply the texture, right? Have you already made material presets, or are you applying the new textures in the Surface pane?
I'm applying the new textures in the surface pane
So you're loading the two shoes the same way, but one of them is using a different shader?
