Do Morph Injections work in DS 4.8 Pro ???
I'm running DS 4.8 Pro. I have V4 in my runtime and have been trying to inject the morp++ morphs. No matter what I do the morphs don't appear in V4's parameters. Also a few of the hair products for V4 (Magix 3D etc) also need to have morphs injected into them before use. I can't get these morphs to inject either. Can't you inject morphs in DS 4.8 Pro ????
    Working fine with v4 for me -- are you getting any error messages?  Are you using the Parameters pane?
  • StratDragonStratDragon Posts: 3,289
    are you using a modified v4 or a stock one?
    inj work but I have an issue with modded figures (perfect V4 package) and some of my legacy work wont load the scene with the injections intact and I have to re-inject them, sometimes it doesn't work at all.
    Stock V4.  I don't have perfect V4 so I don't know if there's an issue with how it's set up.
    Can you name some hairs that aren't injecting?
  • BejaymacBejaymac Posts: 2,002
    Did you run the .bat file to generate the needed files, the old installers used to run it for you, but DIM doesn't,
    "Runtime > Libraries > !DAZ", in there you will find DzCreateExPFiles-V4.bat (think it's a .command file on a mac), double click it to run it.
    DIM does run it, but manually extracting the zip doesn't.
  • StrixowlStrixowl Posts: 301
    No error messages and yes I'm using the parameters pane.
    Using stock V4.
    A few of the hairs I've attempted to inject are Destiny Hair & Embrace hair by Magix 3D (Magix 101) and I suspect some of his other hairs I haven't checked yet.
    Not clear at what point I would run the DzCreateExPFiles-V4.bat. I'm on PC.
    I always do manual installs because of previous issues with installers putting files all over the place. Any way so to get the Morphs to inject do I have to use DIM ???   frown
    Make sure V4 and all morph packs are installed to the same content folder, and you only have one content folder with a "Runtime:Libraries:!DAZ:Victoria 4" folder, and that that content folder is writeable (i.e. not in Program Files).  In Windows Explorer go to "Runtime:Libraries:!DAZ" and double-click DzCreateExPFiles-V4.bat.  A black window will open up, all the morphs will scroll past, and the window will close if it was successful.  Then load a fresh stock V4 and try the morph injection.
    Just tried Embrace Hair, the injections work, make sure you have the "Main-Hair" bone selected when you look in the Parameters pane as that's where the morphs are, not the root.
    Fixmypcmike
    Thank you so much. Running the DzCreateExPFiles-V4.bat solved the problems with Morphs ++ and the hairs I've tried smiley
