FWSA Gillian HD for Victoria 7 and LF Sorbet Swimwear question
RuphussRuphuss Posts: 2,631
do the nipples poke through or does the top move with them ?
a lot of garment is not moving with the nipples so thats a big annoyance to me
    Collision modifiers should take care of all collision.
  • RuphussRuphuss Posts: 2,631
    and who is the one that should take care  ?
  • scathascatha Posts: 756
    Obviously, you do...  :P
    be aware of the obvious
  • nicsttnicstt Posts: 11,715
    Not seeing any nipples really; if it is a problem, just reduce them though.
    I must admit, the novelty of having a swimsuit bundled with a character was very refreshing. :)
    All joking aside, it does very much suite her figure.
    you miss the point
    i want to see them not hide them
    still no usefull answer for my question which is meant serious
  • DigiDotzDigiDotz Posts: 515
    I think you need Genesis 3 body morphs  http://www.daz3d.com/genesis-3-female-body-morphs
    using that will push those areas of the swimwear out
    If they don't show, then adjusting, applying morphs will make them show.
    2560 x 1440 - 765K
  • SimonJMSimonJM Posts: 6,101
    If all else fails a small use of a couple of Dformers should do the job!
    I can never understand why people think that nipples are prominent all the time.   For example
    Ours not to reason why ... but you got to admit, it'd be handy for you girlies, if you want to be cat burglars; no need to carry glass-cutters with you in your tight, form-hugging catsuit that you all wear, all the time, except when slinking around in your scanties, just unzip a little and wiggle up against the glass, and voila ..! devilcheeky
  • WilmapWilmap Posts: 2,917
    Have to agree with chohole. I think they look silly myself.
  • BlumBlumShubBlumBlumShub Posts: 1,108
    edited August 2015
    I don't think people think nipples are prominent all the time.  I just think people make nipples prominent so that we concentrate on that rather than finding their mistakes!
    Post edited by BlumBlumShub on
  • StrixowlStrixowl Posts: 301
    How bout some folks like nipples, others don't. I know I do smiley
  • Oso3DOso3D Posts: 15,118
    edited August 2015
    Post edited by Oso3D on
  • AshcloudAshcloud Posts: 49
    If you want to avoid having the nipples poking through the garment, try adding a smoothing modifier to the garment and maybe a push modifier. Both are available in the Scene menu (Edit > Geometry).
    so you all think its me to let a product work like it should
    and now also useless answers from a mod
  • TaozTaoz Posts: 10,351
    I think everyone likes them at least the first year or so of their lives... wink
  • BeeMKayBeeMKay Posts: 7,019
    edited August 2015
    *patpat* Well, you post a question about that topic, it quite easily derails because all they see is the word "nipple", and not the question you have asked about the product...
    Maybe someone who has this set is kind enough to dial in the nipples, and renders an image so the question will finally be answered, and we can see if the swim suit in question does or does not show nipple-related poke-through?
    Just a thought. smiley
    Post edited by BeeMKay on
  • cunningfcunningf Posts: 32
    The swimwear follows the nipples, There is no poke-through.
    I'm not in a position to show a render right now but if you need it I'll throw one up when I get home from work.
    edited August 2015
    There's the danger of a locked nipple thread..
    Post edited by DigiDotz on
    OOh   locked nipples sounds painful
    A simple screen shot of the model viewed in Wire Shaded mode will show if the model has enough mesh density to follow the figures nipple morph.  I wish vendors would include wire shaded views in their promos.
  • CybersoxCybersox Posts: 9,938
    Depends on what they're locked to.  Braces would be especially bad.
  • bsettbsett Posts: 74
    No pokies as you can see in the textured pic but as you can also see in the wireframe it’s really close.
    1314 x 1644 - 1M
    887 x 1200 - 352K
    thank you all for your help
    i also hope it is a little future advice for the garment crafters
