How do I rename frames?
EightiesIsEnoughEightiesIsEnough Posts: 1,265
edited December 2022 in Daz Studio Discussion
I purchased the Batch Render script from Renderosity about a month ago, and I did learn on the documentation that frames can be renamed in DAZ Studio.  How can I rename frames so that I could render multiple frames in the timeline?
Post edited by EightiesIsEnough on
  • What do you mean by naming or renaming frames?
  • From the manual for Batch Render script:
    The frame number is zero-based. You can name a single frame, several frames separated by comma,
    a frame range with a start and end frame divided by a minus, or a combination of this. For example,
    "1,3-5,7" will render the frames 1, 3, 4, 5, and 7. The frame option is ignored when the renderer is
    set to render an animation.
  • EightiesIsEnoughEightiesIsEnough Posts: 1,265
    I figured out the problem.  I had to double click an area in the column in the File List area. I entered the range of frames in the column on each line.
    Problem solved.
