Transfer utility from custom pose
Hi ! Since a really long time i try to use transfer utility with a custom pose. I mean,
- I use a G8F model
- i apply a custom pose
- I send my G8F as OBJ to marvelous designer
- I create my clothe, simulate on my G8F pose (not the basic T pose)
- I import the clothe create with marvelous designer to DAZ.
- NOW i want to use Transfer Utilty to create a figure.
The problem is, when you use transfer utility DAZ always restore your pose to ZERO and then create the figure.
Someone can help me ?
  • felisfelis Posts: 6,498
    When you say create a figure, I assume you want to create a clothing item?
    If the source in transfer rigging is not in default pose and/or base shape, you have to set shape to 'current' and expand options and check 'reverse source shape from target'.
  • @felis, thank you!  That worked for me.  After fiddling around with (and failing with) the transfer utility for a while, it turns out all I needed to do was check that "reverse source shape from target" box.  Thanks again.
