Question????? Total Iray Lighting by Magix 101
Strixowl
in The Commons
Purchased this wonderful set but cannot find an intesity control on any of the lights. Any idea how intensity can be adjusted? Way to bright out of the box.
Thank you,
Iray lights should usually be adjusted with the Luminance value - do you have that?
Hi Richard
Yes I have the Luminance slider but it doesn'r seem to make much difference at either high or low settings.
Below the luminance slider is another setting with drop down menus play with those a bit. Everything from cmdr/2 to Wattage. Those change the way the luminance value is calculated. If its a mesh light that is...if its a photometric light its based just on lumens...it defaults to 1500 lumens which is just way to low to do anything bump them up to like 150,000 lumens or more. I have seen people bump them up to a million lumens.
Check that the camera headlamp is off.
Ok thanks for the suggestions. Will give them a go :)
