Blue Gorilla
vonHobovonHobo Posts: 1,715
edited December 2022 in The Commons
https://www.daz3d.com/gorilla-for-genesis-8-male
The gorilla renders in blue fur. I wanted to attach the render but DAZ is just timing out on uploads right now.
I had this same problem with the black panther.
I am using the Catalyzer 1.9.0.0 plugin (requires 1.7+) so is it the catalyzer or the product that is causing the blue fur?
Is there any way to fix these issues?
Post edited by vonHobo on
  • MelanieLMelanieL Posts: 7,886
    Are you definitely rendering using the render button in the Catalyzer window (not the normal render button/shortcut)?
  • GordigGordig Posts: 10,822
    From what I remember, using the normal render button instead of Catalyzer's just leads to the fur not rendering at all.
  • The catalyzer version renders blue for me, too.
  • vonHobovonHobo Posts: 1,715
    Yes, using the render button in the Catalyzer window.
    Luckily, there are three versions of the gorilla:
     dForce Fur
    Catalyzer
    LAHM
    As you can see in the attached images, it's only the black catalyzer gorilla that renders slightly blue (first two images). The dForce Gorilla renders OK (third image).
    I had this same problem with the Black Panther, but unfortunately the panther has no dForce version so I just gave up and uninstalled it.
    Interestingly, the albino catalyzer gorilla renders without blue overtones, so it must be something about black fur that is the issue.
    1293 x 731 - 453K
    1500 x 1200 - 299K
    1500 x 1200 - 280K
    1500 x 1200 - 407K
  • FishtalesFishtales Posts: 6,238
    edited January 2023
    It looks like the Silverback that looks blue when rendered. This is using Sun and Sky for lighting.
    Click on image for full size.
    1920 x 1080 - 900K
    Post edited by Fishtales on
  • AgitatedRiotAgitatedRiot Posts: 4,768
    Grape Ape
    Grape Ape
    laugh
